ip vrrp <1-255> preempt-mode enable
Enables preempt mode for vrrp (v3). If a new router is added to the network with its priority higher than the existing routers, then the new router becomes the master.
Syntax
Command Parameters
<1-255>
Specifies a unique integer value that represents the virtual router ID. The virtual router acts as the default router for one or more assigned addresses.
Default
The default is enabled.
Command Mode
GigabitEthernet Interface Configuration
